DavidThorn
The car is a late BJ 8. I went to start the car in the garage and relised that after switching on and before actually activating the starter the fuel pump did not stop ticking.
Luckily I was at home and on opening the bonnet could see petrol leaking from the rear carb,it was going down the overflow pipe but also a small amount was coming out of the top of the float bowl,near the securing nut.
Rather than just switch off I tapped the float bowl with a screwdriver and the clicking and leak stopped.
I presume the float was stuck down and the tapping freed it.
On further investigation today I find that the securing nut was loose and would not tighten, I then realised I could pull the nut and bolt out of the float body.
It seems that the float body should have the `bolt` attached to its base and then after fitting the top the nut is screwed on to the `bolt`,but in my case the nut and bolt are together and it seems the `bolt` has become disconnected from the bowl base.
The bottom of the `bolt` does have some cross hatching on it as though it should be an interference fit with carb body, but it inst inferring with anything at present.
I did have a quick look on various web sites but could not see quite how it should be located,or what I can do to sort it out.
Can any one help?
David Thorn
Can any one help?
David Thorn
