Re: BJ-7 Steady Bracket? What is it & where does i
Greg,
Not sure what you mean by "threaded" holes. If I remember correctly, the four fasteners on each side of the car for the splash panels are sheet metal screws, not machine screws.
Robert and Chicken,
In the photo above you will note that I have fabricated aluminum air deflectors that prevent air from escaping around the sides of the radiator. These replace the stock deflector. Since I have just finished my car it remains to be seen if the deflectors work sufficiently to help keep the running temperature down. If my new approach doesn't work, I will just go back to the original. I will add that installing the deflectors I made was much easier than the Rube Goldberg set up.
Lin
1960 BT7 "The Bloody Beast"
1959 AN5 Bugeye
