Took advantage of a somewhat favorable exchange and purchased some goodies from Denis Welch Motosports. Items included a replacement gear lever and brass bush. Any pointers on installation? The brass bush is in three pieces, does the whole three piece assembly press onto the shift ball with the snap ring keeping it in place or are the two brass halves located onto the shift ball followed by rolling the snap ring into its recess? How is the gear lever removed? Appears that a snap ring and spring keep it in place, but there may be a locating pin to drive in/out towards the base. Any suggestions would be appreciated. GONZO
Hi Guest!
