I don't have an amplifier.guzzul said:The two leads coming off the pickup inside the distributor do not connect to the coil. This pickup is itself just a small magnetic coil. When one of the little bars in the reluctor, which is mounted on the dizzy shaft, pass the pickup, this generates a small voltage within the pickup that triggers a transistor inside the amplifier unit.
