Velox
Ok, this is for those who have NOT read every thread on this forum. If you HAD read everything you would know that unless you have the rear main seal add-on mod then it may be a problem if you, say, put the front of your Healey up on stands, as far as the usual leaks go...
Well I was changing to a gear reduction starter, put the car up in the front, went back the next day to continue the project, found a 6 inch puddle of oil underneath where there is the usual "marking territory" small drip /ubbthreads/images/graemlins/ooo.gif and got ready to tear everything apart to investigate this "new" problem. Doh /ubbthreads/images/graemlins/crazyeyes.gif found the forum thread on rear main seals and where it was written the original seals spin the oil back into the pan when the engine is RUNNING but do nothing for gravity loss, say, when the car is standing up on it's rear /ubbthreads/images/graemlins/nonod.gif /ubbthreads/images/graemlins/nonod.gif /ubbthreads/images/graemlins/nonod.gif and not running...
All this of course has NOTHING to do with topping off the oil level to the very highest level on the stick /ubbthreads/images/graemlins/rolleyes.gif /ubbthreads/images/graemlins/rolleyes.gif as if that extra ounce or two will make it run better...
So now that extra ounce is on my floor and (shock and awe) when I took the car off the front stands the leak quit.
Anyway, just another reason to keep reading all the posts /ubbthreads/images/graemlins/cheers.gif
On a fun note, I got my new aluminum valve cover in the mail today, it's really well done, I'll post a picture once I get it put on.
