regularman
I got all new pads and shoes and all and a full brake pedal, but you have to stand on it to stop the car. Not sure if I could lock it up and slide the wheels or not. Is this normal?
Hi Guest!
I went through all that and tested it before. The brake light and warning actuator if one system fails works good. Come to think of it maybe I do need to adjust the rear. When my wife was driving and I didn't think she was going to get stopped I pulled up the E-brake and it worked well and slid the tires. You would think that it would work the same with the pedal. I got bad knees to so I must think on this one a while.highhilleer said:Does your brake light work? (Mine doesn't) If your brake light isn't working and you have a dual master cylinder, it is possible your Pressure Differential Warning Actuator is activated to one side and you are not getting full braking on both ends of the car. I think this is my current problem. Here is an article on the evil device:
https://www.vtr.org/maintain/pdwa.shtml
