equiprx said:
I have a bunch of small stainless j clips I don't need. What size do you need?
I now know they are called spire nuts and also speed nuts. The stainless kit called them J clips so that is what I went with. Sorry for any confusion.
If I can get them in stainless that would be ideal, otherwise I will give moss, or lbcarco a little of my money.
Equiprx
Thanks for the offer, especially if they are Stainless. I am not sure how many you have but I am looking to outfit the whole car. Anything will be better than nothing.
QTY- 56
The dimensions for the clip is
5/8 wide x 1 inch long
The hole is offset 5/8 inch from the bent u section
The inner width is about 1/8
The hole is for a 1/4 inch bolt. These are ACME threads but I don't think that matters since unless your clips have actual threads.
QTY-8
There is one more size it is identical to the dimensions above except
the length is 11/16
the hole is offset 7/16 from the bend.
The dimensions only need to be close since these parts have a fair amount of play. Let me know if you have anything and what we can work out.
