AUSMHLY
What's the best 7" non sealed headlamp?
How did this question come up with me? My other car was in an accident. Body shop replaced the passenger headlamp assembly with an aftermarket unit. Looks almost identical, until you look closely at how the internal reflection differs slightly. The aftermarket headlight was not as bright and the reflection didn't match that of the OEM drivers headlamp. So I replaced all the bulbs in both headlamps with new and it made no difference. I ended up buying a used OEM passenger assembly. More than not the saying is true, you get what you pay for. OEM new $400, aftermarket $80. OEM used $30 (needed to wet sand to clear). Both headlights beams are now identical in light output and dispersion.
A while ago I installed a set of Lucas PL700 headlamps. Back in the day it was used on the Jags and it's design looks very retro. Seems I didn't do enough research about that headlamp. Don't believe it's DOT approved. I also wonder about how well it's design is at reflecting the more modern bulbs. Halogen, HID, LED bulbs. I have halogen bulbs in the PL700 and not sure I'm getting the full performance from the combination. (I currently have another thread about LED headlamp bulbs on this forum.) I need to be brought up to speed about which non sealed 7" headlamp will work with the upgraded H4 bulbs. I like the look of the PL700, but not sure if it's compatible with the newer bulbs? I've read good things about Hella, Bosch and Cibie headlamps.
So I'm wondering if the PL700 is the right choice. Maybe swapping it out for a Hella Vision Plus headlamp and my current H4 halogen bulb will provide a better result? If that's true, then I can move forward to if HID or LED will improve on that.
