jjbunn
Harold starts readily enough. I don't use any choke, figuring it's warm enough in SoCal. Once started, tickover is about 1500rpm. Manifold vacuum is 20psi, engine oil pressure is between 50 and 75psi. If I set it the tickover lower using the adjustment screws on the carbs, the engine tends to run roughly. Using more choke doesn't seem to make much difference.
Until the engine has been running awhile, pressing the gas pedal tends to make the engine splutter and die.
I have a feeling I need to adjust the carbs. The plugs are new, as are the plug wires. The distributor cap and points are in great condition, and I've cleaned them.
One doubt I have is that the plug gap I'm using is .035, whereas I have seen various numbers, e.g. .025 in the Bentley manual. Is 0.035 good?
I've also cleaned the pistons and needles in both carbs, and the float chambers.
(Harold used to have emissions equipment installed at some point in its life, but all that is connected now is the breather tube from the cylinder head.)
I have replaced the non-stock airfilters with new ones of my own design (pictured in a previous post). When tinkering/tuning the carbs, should this be done without the air filters in place?
In short, I'd welcome some advice on how to approach getting the engine to idle correctly (I think at 900 rpm), what areas to look at first, what literature to read, and so on.
