Bed Liner As Undercoating
Gray_Cat
If you have used bed liner as undercoating for your Spridget what type did you use? That is, was it rattle can or sprayed on with a gun?
If you used a gun, what size nozzle did you use? Any information would be greatly appreciated.
Roy :cooler:
While it wasn't on a Spridget, I've used rattle can to coat the bottom and interior floor pan of a geo tracker. It worked well and was an easy DIY application. It's a spare farm vehicle, but I was pleasantly surprised with how well it looked when it dried.
I believe the product I used was the Herculiner. Black on the undercarriage and red in the wheelwells to work with the red paint. If I remember correctly, it went on pretty easily with a brush, just make sure the areas you are applying it to are as clean as possible. Still looks good IMHO
