OK, here's a subject I have a great deal of knowledge on, if you have .003' clearence and you are seeing low oil pressure, would .003" clearence cause this ???
You better beleive it!!!!!!!!!!!!!
Let me tell you a little story about rod clearences that wil shed some light on this subjest. About three years ago, I had a two time SCCA HP national champion and his crew chief approach me at the runoffs, they wanted me to build them a bottom end for 1275 race engine, they had a spec sheet telling me every spec on the motor and wanted me to deliver to them this blueprint in the engine. Their spec was .0025" for rod bearing clearence, I normally bult to .002" for a race motor, and .0015" for a street motor, but I fiquired, what the hay, they are national champions, and really smart guys, they must know more than me. At the same time I built their bottom end I started on a HP 1275 race engine for mytself and followed thier spec sheet and the .0025" clearences on the rods. Got the engine built, it ran great, but I always struggled with oil pressure, ended up regulated the pressure reilef valve higher by making it adjustable, and using 9/16" ball bearing in place of the cup, with the adjustment pegged, all I would every get was 60 psi cold, at 45-50 in the heat of race, much lower than I was accustom to seeing. After picking alot of people's minds we came to the conclusion that the rod clearence was too great, and even as little as .0005" could make a big difference in pressure, now mind you during all this I tried several oil pumps with no gains in pressure, and side thrust clearence was dead on the money. Finally I decided to bite the bullet and take the engine down and do whatever I needed to do to get it back .002" on rod clearence. I did so, rebuilt the motor, fired it up for the first time, with the pressure regulator still pegged, and immediately pegged the oil pressure guage, then had to back off the adjustable regulator big time, now the engine has a nice 85-90 when first cranked cold, and then settles into a nice 75-80 for the entire race. Turns out my customer who also had a engine speced this way had been suffering the same problem, did what I did as well and saw the same sucess. So the moral of all this is rod bearing clearence is DIRECTY reated to oil pressure in a big way, and if you have .003" clearence time to rethink it down there and on a street engine get it back to .0015", you are twice what I recommend for a street engine, and I'd bet good money that this is your problem without knowing anything else. If you think you see red flashing lights and hear sirens going off in my post, you are correct!
