BE vacuum advance line and fittings
Whitephrog
Is the vacuum advance line and fittings for a Bugeye the same as the one for an MGA (original MGA p/n 1H919)?
That looks close to the setup for H1 SUs and an original vacuum unit. If you have HS2s the port is on the front carb and connected to the pipe with a rubber sleeve. For this setup I used Moss' offering for a big Healey.
I just use rubber tubing. Simple, easy to disconnect. If you're doing a resto, ignore this post.
