twas_brillig
Several years ago I replaced the rear quarter elliptics (which are held in place by a large diameter 'U' clamp plus two smaller diameter bolts that run up throught the bottom mounting plate, the spring itself, and thread into a solid piece of steel that is notched to fit over the spring and tapped and threaded to accept the bolts.
I've just pulled the springs, and found that the threads are basically gone on all four bolts and in the securing steel chunk. The bolts are roughly 1/4-5/16 inch in shaft diameter and fine thread. It appears that I managed to overtighten and strip all four of them, but I find that very difficult to believe (there's no torque settings for tightening these) as I would've used hand tools, mostly likely a half inch drive ratchet, and I ain't got big thick forearms.
Anyone run into this before? Any suggestions? I've ordered new bits from Jolly Olde England.
Thanks,
Doug
Thanks,
Doug
Hi Guest!
