BE Headlight Relays- Photos
lbcfan
I've had the car since '69 and the headlights have always been dim. I wanted to install relays to take the load off the light switch, but I didn't want to make any permanent changes to the car.
The link shows how I mounted the relays and wiring. Not one new hole. Also- used all bullet connectors so that the relays can be removed and the original connections plugged back in. Hope this is helpful to someone...
The harness is a cheap set from VBM.
https://www.imagehosting.com/photo/albums/headlight-relays
Thanks!
