Was going to put the old springs in the blast cabinet to clean up and noticed that there was a rubber wedge stuck in one. Concluded, incorrectly, that it might be a bit weak and was thinking about replacing.
Noticed that there are several springs available depending upon which sprite your have (not including racing or lowering applications).
I have a later model wire wheel disc brake front end to install on the BE. Which spring would be applicable, BE or later model?
