Converting Bugeye over to dual brake line system. Should I have any concern regarding the switch when I fill and bleed the system. I assume it is a pressure switch with a shuttle that slides to one side upon differential pressure. Do I need to "center" it sometime in the process. I assume that the two line sytems are discreet within the unit and it acts only as a warning. Any idea how to wire up a light?
Hi Guest!
