emann
Had the Engine out to replace the clutch.
Got it back in and running.
New clutch won't allow changing gears without grinding.
After much fiddling, bleeding, adjusting, research, couldn't get it solved.
Saw Jack's post about adding a nut inside the slave cylinder to lengthen the pushrod.
This works - thanks Jack.
<span style="font-weight: bold">Does this suggest that I should purchase a new pushrod and get the longer one that is normally for the later engines?</span>
Replaced all 3 pieces when I did the clutch, doesn't seem to be any play in the bushings, the release bearing arm "could" be bent - didn't think to check when the engine was out.
I'm thinking now that the old clutch was probably fine. I was replacing it due to severe slippage, but I'm thinking now that I just had it adjusted so far to allow changing gears, that I was actually pressing the release bearing against the clutch all the time.
TIA,
Ed
TIA,
Ed
