Battery to use?
LanceLyon
I'm getting ready to fire up my barn project after sitting for 25 years. It is in no way ready for anything except the brief satisfaction of getting it running before I begin in earnest the frame-off restoration.
Does Sears offer a battery that fits a BJ7? If not using an "original" style battery, what does everyone use?
I put a deep cycle marine battery in my BJ7 because it was not a daily driver. The posts have theaded studs that go thru the helmet type cable fittings and do a wonderful job of holding the cables in place. Not having to drill holes in the top of the battery electrodes is also a plus.
SB
SB,
I know that you are trying to keep the car as original as possible, & commend you for it.
In my opinion, the helmet type connectors are NOT one of the Lucas better ideas. The fully enclosed connection seems a perfect place to breed corrosion & bad connections & it can't be detected by simple inspection. Also due to the short taper of the fit it is easy for the helmet to become stretched, Then there will never be a good connection due to contact on the top of the posts only.
This is one area where I choose to sacrifice originality for reliability & use the "better" standard clamp connections. As you would guess from my tone, I also don't use the battery disconnect switch for the same reason.
Dave;
I personally think Lucas never had a good electrical idea. My favorite is linen wrapped and varnished wiring in my Bentley S1, now there was a brilliant idea.
Someone said in their signature...loosely paraphrased; If Lucas designed and built weaponry, wars would never start. Gods’ honest truth as far as I've experienced.
I'm not an electrical engineer but I did read somewhere that installing a larger capacity battery than original will over tax the generator and the regulator. IMHO Unless you've installed an alternator, I would stick with the correct size battery.
Anyway, if you're just going to get the car running, why not use a spare battery? I wouldn't purchase a new battery until the car is near completion.
[ 02-05-2004: Message edited by: Johnny ]</p>
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Johnny:
<hr></blockquote>
Actually, with the Lucas RB type control box, Which is used on many British cars of the era, the current is limited to a safe value no matter what the battery size. A larger battery would just take longer to be fully charged. In the following reference, note the "series coil Fig 5-1"
https://home.tiscali.be/jozef.neefs/NL/tecnics/RB106.htm
Johnny,
I did begin the process by removing the battery from my other car to work on the Healey, but I got tired of re-setting all of my radio stations everytime I did!
I ended up taking ThomP's recommendation and purchased a type 27 Die-Hard to get me through the early stages of restoration while I drive my wreck for fun. It sounds as though I will end up with an Optima battery when I am finally done with the project, perhaps in a couple of years!
Thanks for everyone's input and help. Where would I be without the rest of you?
