I can fully relate. I had YEARS of ignition problems due to a ballast resistor and the fact that I had no idea what they did. I replaced everything on the car including carbs, distributor, fuel pump, filters, etc etc,... even tried a handful of different coils and nothing worked. The car got parked for about 6 or 7 years because I couldn't make it run reliably. After the 7 years or so when it came back out of storage, wouldn't you know it, same problems. One day I finally narrowed it down to the coil (even though it was brand new out of the box Mallory) and went down to the local auto parts store to have them test it. He said it was hot but checked out fine and then he asked me what size ballast resistor i was using. "Ballast resistor?" I replied rather sheepishly. Turns out the ballast resistor lowers the amount of voltage going through the ignition system which keeps from burning up the coil and points etc. Once he said this I realized that in all those years of car problems, I would always stop on the side of the road to reset the points gap (my father, not knowing much more than I always told me the problem was the points "floating"). When I stopped on the side of the road and popped the cap, what was actually happening was I was venting out the distributor enough that the points would cool back down and the coil would have time to cool off a bit as well, then when I buttoned it all back up, whaddya know, it would run again, of course it would only be a matter of time before I would get the same problem but since in those days I never drove the car much more than 15 miles, it would only happen about once per trip. The guy at the auto-parts store offered to sell me the proper ballast resistor to go with the mallory but since I was stuck on the side of the road, instead I had him sell me a coil with a built in ballast resistor. That way I was able to install the new coil in the dark on the shoulder of a freeway on ramp and, wouldn't you know it, I've never had the problem since. Also, since then, I've installed an MSD-6AL box and gone back to the original Mallory which, when you run an MSD box, you don't need a ballast resistor because the box does the work for you. SO, to make a long story at least worth while, here's the info you're looking for. The ballast resistor for spridgets, according to the Haynes Manual was only fitted on later model cars with the 15C6 coil and should be 1.3 to 1.5 ohms. The LA12 coil fitted on 948 and 1048 engines had a primary resistance of 3.2 to 3.4ohms and the 11C12 and HA12 coils 3.0 to 3.ohms. Hope this helps!
