Stewart
I'm trying to figure out what my next plan of attack will be.
Right now the 73 with hif4's and a 45d4. I just leaned the carbs out as it was running rich as its now close to 45 degrees warmer than when they were initialy set. Before that it did do the same thing but not as bad and this started within the last few days.
In first or second gear at just over 4k it will start backfiring rapidly through the muffler with a rare pop through a carb. Once you get to third its fine to redline 4th I haven't run it that high yet. When I rev it out of gear it will blow thick black smoke at 4500 when it starts poping otherwise no smoke noticed.
I'm thinking ignition related and will be pulling the dizzy to check set point gap/condition but I'm no su guru so I dont know if that could also be it?
Hi Guest!
