CJD
Alright, finally getting to the sidescreens. Does anyone have a good supplier for the "fuzzy channel" that holds the plexi-windows?
That's the easy part.
Jesus, if you are out there, I have removed the vinyl and am trying to get a feel for the order that these sew together. Studying the stitching, mine were originally sewn as follows:
1) Inner arches sewn to inner base, so the inner vinyl is a combination of 3 separate pieces...but were sewn together BEFORE the inner was attached to the outer vinyl.
2) The outer vinyl was cut as a SINGLE piece, that covered both the base and arch.
3) The inner vinyl cover was then sewn to the outer vinyl cover, inside out. This assembly was then turned right side out and slipped over the frame.
4) The windows and channels were used to "pinch" the edges of the vinyl and lock them to the window frame.
All of this I get from the original stitching. The part I do not get, though, is why the inner vinyl was cut in 3 pieces. It seems that it can be done with a single piece, just as the outside. I am thinking it may have been just to make the vinyl usage more efficient...that is...to get more pieces out of a given sheet of vinyl.
So, are everyone else's screens cut using 3 pieces of vinyl on the inside?
This is the one-piece outside
And this is the inside, where you can see the seems at the corners of the window arch
John
John
