[ QUOTE ]
Well, you can certainly time the car by ear and get it darn close. But if your timing has to be way off in order to run right, you may have other issues and changing the timing may just be a band-aid. Perhaps a full tune-up is in order? Have you inspected the condition of the distributor and advance mechanism?
[/ QUOTE ]
I have replaced the Dizzy cap, rotor, condensor, points, plugs & wires. I do not know how to check the condition of the Distibutor or advance mechanisim. I can tell you that the noise is much worse now after I re-adjusted the valves to .012" while hot. Does that tell you anything? All valves go up & down quite nicely unless I missed something.
[/ QUOTE ]
Hi Guest!
