Banjo
Forums are wonderful... they're an endless source of info about whatever you need (or don't) Anyway...
My CJ is running like dukie. the general consensus on the CJ forum is I have the Carter carb woes. And I fully believe them. A cheap alternative is the ever durable Autolite / Motorcraft 2100 2bbl that was used throught the 60s-70s- and a bit into the 80s on Fords and AMCs
So I'm puttin a call out on a decent one from the 70s vintage (gotta be pre emissions) hopefully one that is stamped "108" under the accelerator pump linkage on the side of the carb.
They would have been found on the ford 300-302-330-351-390s
or AMC 304 (among several others).
If anybody has one that they wanna part with on the cheap, lemme know.
I am dong a scouting run to the u-pull-it this weekend, and I may find one, but I wanna get some options.
Thanks guys (and gals)
Banjo
Banjo
