I have an 1958 Austin Healey BN6.
The fuel gauge reads empty all the time. The grn/blk wire from the sender to the gauge reads zero ohms when detached at both ends. The grn/blk wire reads 5 volts when attached to sender and gauge. The double green wire reads 12.3 volts when either attached or detached from gauge. When the sender is removed from the tank with one test lead attached to the body of the sender and the other attached to the post on the sender readings of 10 to 80 ohms occur when the float is raised. The tank is about 1/4 full.
I don't know what the voltage readings are supposed to be and it seems that the new sender is working properly. Does the fuel gauge need work? If so instructions on how to disassemble, inspect and repair would be helpful.
Hi Guest!
