Austin healey BT7
Paul pugh
Can you tighten a loose crankshaft pulley nut with the engine in the car? How does it get loose? Looks like you can remove the radiator and get to the nut . The nut on my car rubs on the frame, just happened. Help!
I'm thinking you'll need to raise the engine up to clear the crossmember to fit a socket. You'll want to tighten it so it doesn't wear out the key channel. It doesn't need to be overtightened , and you'll need to remove the radiator. A couple bangs with an air impact will do it. It probably wan't tightened enough to start with.
Just did this on my BJ8 in order to change the timing cover seal. It's a bear. The nut should be secured with a foldover-type lockwasher. The nut is 1&11/16" I bought a socket and a 3/4" impact wrench at Harbor Freight, but the wrench is too big to fit in front of the X-brace, and I bodged-up the nut and had to buy a new one.
You might be able to get at it from underneath with a big crescent wrench, or even a pipe wrench. Then, hopefully, you have an unused portion of the lockwasher you can fold over one of the nut flats. It should be torqued tight--I believe the spec is 150 ft-lbs. You'll have to lock up the drive train; maybe put the car in gear with the hand brake on full and someone standing on the brakes, or pull the starter and jam a pry bar against the ring gear (or both!).
When raising the engine (I am doing this (again) today) it is a good idea to remove the throttle linkage and the front air filter to allow for no damage to the fender and carbs. I use an eight to ten inch two by four at the front of the oil pan when raising the engine. I have used the long 1/4 in bolt idea in the past and it works well. All you need is one. I've gotten to the point where I can do it in 4 hours. This will be my third time.
TH
Well it did take the full four hours. The power went out for 7 hours due to a thunder storm. My wife held flashlights and the compressor tank was full. Kind of like road side repairs.
TH
I heard about that thunder storm!
Yes, the radiator needs to be removed and I agree with the wrench size. I have a 2-ft one from Northern Tools to turn the engine over. Make sure that lock washer is folded over a flat.
