mbrooks
I've cut-&-pasted below an old email from Dave Russell I found on a search. Since moving to Milano Italy I do not have the nice big double garage to do work on the BN2. Cutting a long story short, I recently had some work done by a mechanic I met through the Healey club in Milano. He's done some good work, but insisted on refilling the gearbox/overdrive with ATF. Since then, when everything is up to temperature, and with the O/D switched on, the O/D drops out on its own if I accelerate hard. Note that the throttle switch is completely bypassed - only the toggle switch on the dash and the gearbox switch [the one that allows 3rd/4th only] are in circuit.
I suspect that the lower viscosity ATF is causing O/D clutch slip due to lower hydraulic pressure, but I would really welcome some second opinions.
Rgds
Mike Brooks
[Old posting by Dave]
Bob,
This is one case where shooting from the hip doesn't work. A lot of people get fooled by the two different rating temperatures of gear oil & engine oil. Gear oil viscosity is usually rated at 100 degrees F. Motor oil viscosity is rated at 212 degrees F. Thus the viscosity of SAE 75W-90 gear oil is roughly equivalent to SAE 10W-50 engine oil.
A lot of people are having very good results with Redline MTL which is rated 75W-80 & Redline MT-90 which is rated 75W-90. These oils are rated GL-4 which means they don't have the sulfur compounds that destroy bronze synchronizers as do the GL-5 rated oils with sulfur which is needed for the higher contact pressures in hypoid axles.
These Redline oils are compounded to have a higher friction coefficient which enhances the synchro ring "grabbing" & usually results in quicker & easier shifting. A "good" motor oil is actually too slick for the synchros to work at optimum. As are "slick" additives. The Laycock overdrive clutches also benefit from a less slick oil.
BTW - ATF oils are usually rated around 5W-20 on the engine scale. Not too far off from the SU carb recommended 20 wt.
Rgds
Mike Brooks
Bob,
