Article: Turn signals - from working fine to gone!
  • Thread starter Deleted member 25859
  • Start date
Hello, My first idea is that you should move this question to the MG forum section of this web site. There are plenty of MG people there.
But I can give a few things to look at since I have worked on many MGs. On the B's the connectors under the dash sometimes get disturbed and lose connection so make sure they are well seated. Also if you separated any of the connectors especially some under the dash then check them again because the plug configurations are so close that they can be intermixed. look closely at the wire colours to make sure you are putting the right plug to the right connector. Since you changed your master cylinders it is possible that you loosened some connections or reconnected them wrong. Go luck and talk to the boys and girls on the MG forum. Just hit forum buttom and scroll down.
