Dougal
Hi All
Have been rebuilding my steering and suspension and needed to replace my king pins. Problem is, now I have started to put things back together i find that my new pins will not fit. The bottom of the pin with the bore for the screwed fulcrum is larger and fouls the brake drum back plate see pic 1. This could be fixed by grinding back the edge of the forging.
More importantly the bore for the screwed bush is approximately 8mm lower on the new pin (pic 2). I'm not sure what effect this will have on the steering geometry. The machined part of the pin above the screwed bush bore is identical to the old one. The offset of the bore centre to the centre line of the pin is also the same.
Of course your all wondering why I don't just take the pins back to the supplier. Reason is i'm down here in New Zealand and I bought the parts from one of the larger suppliers in the US (came in a box labeled made in England). It took a good few months to get them here in the first place and I have had new bushes machined in my stub axles to suit. So I would prefer to use what I have.
So my questions are:
1. Do you think the new pins are Austin Healey 100 pins.
2. Will the 8mm difference have any real effect on the setup.
Thanks in advance for your comments
Dougal
Dougal
Hi Guest!
