I have a lighting issue.
Again, having the Bentley 1500 book open to page 330 is helpful.
When I connect the battery, light #50, the ignition warning light goes on. When I start the car it goes out.
According the the owners Manual - same Bentley book - page 6 I think. this light exists to both remind me that the key is in the ignition and tell me that the engine is not charging. Thus, it should light up at low idle and go off when I accelerate AND it should tell me to turn off the key when the engine is not running.
The obvious solution is to take out the bulb - problem solved. The only problem is that I want it to be right. Any ideas? I tried getting continuity from the alternator but couldn't - I presume because of resistance from the bulb.
any thoughts?
thanks all
any thoughts?
thanks all
