christophe
I rebuilt one set of wheel cylinders on my 100-4 only to have more of them fail later on. All cylinders are either leaking or freezing up. I have drained all fluid from the lines, but the right rear is still locked up. I can't even turn the drum by hand. When i was rebuilding the front drum cylinders, one of the pistons refused to budge out of the wheel cylinder. I tried to pry it, but ended up breaking the wheel cylinder housing. I tried compressed air, but that did not work either.
So, any tips on getting the pistons out of the wheel cylinders?
