Hi Guys,
I'm about to install relays in my Sprite. I'll be using 1 each for high/low beams and one for a reverse spotlight that will we able to be switched on and off from the dash but only when the panel lamps are on and only when reverse is engaged. Could those of you who are good with electrics check my diagram to be sure I've got it right please. One thing I forgot to add to the diagram but that I do have on hand are 30A fuses for between battery and relays.
