Cottontop
I am finally getting around to installing the rear leaf springs that I bought 3-4 years ago. My old stock ones were saggy and only yeilded 3" of ground clearance. While it looked kewel, speed bumps were a bit** !
Although I bought the new springs from a fellow member of our local club, I have tracked them down to having been made by Martin at Jule and I have talked to him.
I've found that the springs are intended for a BJx series and I have a 100-6. That means that I don't have the 1" frame drop below the axle. That means that I need a 1" spacer between the spring and the axle perch in order to get the axle off the axle bump stop and to get the proper ride height.
The problem is that the U-bolts are not long enough with an extra inch of space in there.
At this point, the best 2 options that I can see are:
1) to buy and install longer U-bolts.
2) have the springs re-arched by 1".
Does anybody know where I can find 8" U-bolts for a 2 5/8" axle ?
Thanks in advance.
Tim
Thanks in advance.
Tim
Hi Guest!
