Another rear spring question
Cutlass
I have just completed replacing the rear crossmember (and rear spring mounts) on my '66 BJ8. The distance between the front and rear spring mounts is 35 1/2 inches, center to center, which is what the book says. Problem is that when I attempted to install the leaf springs, the distance between the mounts was great enough to require pulling the shackles toward the mounts with a clamp, an extra inch or so. The springs are new, having come with the car from a previous ugly repair job. Which of the following is true:
1. The mounts are too far apart.
2. The springs are too short.
3. This is the way it's supposed to work.
Thanks in advance for all the help.
The answer is, most likely, #3. Typical springs might be 34" long unloaded, & 36" loaded.
The spring will gain a couple of inches in length as the arch is flattened by the car weight. You just have to anchor the front & stretch out/flatten the spring until the rear shackles will reach & bolt them on. The axle should be bolted to the spring first. I have used a makeshift spring spreader tool consisting of a jack & extension to spread the spring enough to fit the shackles. There are actually spring spreader tools available.
Used springs are usually a little easier because some of the arch has been removed.
Be careful & don't have any accidents. There is quite a bit of energy stored in the stretched spring.
Hi Cutlas, Yes Jacking the spring is the standard method for installing rear springs in the late BJ8 cars.---Keoke
