Another question
jlaird
Just to keep everyones intrest up.
Yep the glass has O rings between it and the gage the chrome rim had something between it and the glass as well. Looked like tar with a fiber in it, what do you supose it was. and what should be used there?
Hi Jack, You can use the Black Ford strip caulking there or DUM DUM---Fwiw-Keoke
Ahh, DUM DUM, bet that's what that was, hard mostly though.
Yes Jack; when it git old it get pretty stiff.---Keoke- /ubbthreads/images/graemlins/grin.gif
Not really sure why it was in there. Dosn't seem to be a reason or need for it?
Keeps the glass from rattling?... as if THAT would be an issue. /ubbthreads/images/graemlins/devilgrin.gif /ubbthreads/images/graemlins/jester.gif
[ QUOTE ]
[/ QUOTE ]
Seems it is already a preaty tight fit with the o ring under the glass.
I have had the occasional loose glass in a guage and it will produce an annoying buzz/rattle. If the o-ring doesn't make it tigh, the dum-dum will fix the problem
Mike
59 Bugeye
69 Sprite
Yep, think I will try to locate some just for effect. Maybe Autozone or my friendly auto body shop. Not much required at all.
Or you might already have some shoe-goo in a drawer, that's what I used on my gauges, worked a charm.
Shoe-goo????????
used for sticking the rubber back on your runners
Ohhhh, sounds like glue to me. Don't think that would be a great idea.
I have a steel knee so no running here.
Tar, Flashing cement, new roof in a tube, like in a caulk tube for ease of squirting it around the gauge. Do NOT use silicon caulk if you ever want to get the glass off in the future.
Oh, ok, I can do that.
