No recollection what camera I used, one of the Nikons for certain. Likely with a 50mm prime. Certainly camera movement, possible subject too. Low shutter speed, most likely 1/30th. And a grab shot. Available light from a window. And film sharp vs. digital sharp is in play also.
The forward sleeve seems to be where the focus point was.
That would do it unless lens had IS. Now that you mention it, the focus does look a bit to the front. The Marketable made a noticeable improvement.Low shutter speed, most likely 1/30th.
Hi Guest!
