I have a different OD problem than TFR. I removed the plate at the OD shifter to replace the seal. I have it back together now and I can't seem to get the solenoid adjusted. I have used the procedure outlined in the Bentley manual. Using the 3/16 rod to hold the arm in place while I adjust the linkage at the solenoid.
The arm will move but it does not go into OD. I cannot test it for a while because I had to remove the gas tank to have it cleaned and sealed.(another story)
Another problem I am having is that the solenoid will not shift sometimes when the switch is operated. (either off or on)I know that it is not electrical because I can remove the neg. battery post and it still will not retract. I can "help" it a little and it will shift in either direction. I have adjusted the linkage several times and tried to move the shifter in and out on the rod to make sure it is not in a bind.
Thanks for any help, Pete
But be a little careful with that dental pick, since there's a precision seat under the ball that could be scratched. A straightened paper clip works well too, if you put a bit of kink in it so it just slides into the hole but puts some pressure on the sides.
