    Thanks and welcome to BCF!
Another n00b.
1974jh5
Ran across this site last night, pretty cool! I'm a long time Brit car nut, have owned at least a dozen Spitfires, a GT6, a TR6, four MGB's, a Herald and currently have two Jensen Healeys. One is a restored 1974 JH5, still on the stock 907 Lotus but the Getrag trans has been replaced by a Toyota 5 speed and has a set of Dellorto DHLA sidedrafts plus some other period correct mods such as Minilite wheels. The other is a retired SCCA ITS car which has been gutted, a cage installed and is powered by a naturally aspirated 13B Mazda rotary which is soon to be replaced by a 13B turbo. It also has the front uprights and brakes from a Miata and a RX2 rear axle with RX7 rear disc brakes and limited slip. I use that one as an autocross and hillclimb car.
Welcome from Charleston.
Sounds like that 74 JH5 should take a run down I26 this month to the British car show.
Cheers,
Irene
Hi There 1974jh5,
"Welcome" to "THEE" best LBC site anywhere but you`ve already found that out.
Should you attend "Eurofest" @ BMW in Greer this Sat. stop by and say Hi.
Enjoy the ride here.
Regards, Russ
Great set of cars there, welcome!
Welcome!
Great to see another JH owner here! There aren't nearly enough of us.
