Since I've learned so much from this group I thought I'd share another lession learned from working with a 46 year-old Lucas wired machine. Just after replacing the points, cond and coil, I drove the car pretty happy with the state of life. Just before I shut the car down, it went stone dead and wouldn't fire. Thank goodness, this time only 50 feet from the garage. Not fuel, definitely electrical. I had weak spark from ignition switch to the coil, intermittent weak spark at the points.
When I bumped the starter to check a spare spark plug against a ground for spark, the car started and then died again! Any guesses yet?
I noticed when I pulled the # 4 plug wire with the spare plug to a grounding spot, I also put tension on the ignition-to-coil wire and that resulted in intermittant plug spark or started/stopped the engine. That led me to the connector to the coil. When I slit open the plactic protector over the wire and clip, I could see that there was little left of the copper wire adhering to the clip.
I stripped and trimmed clean wire, soldered it to the clip and had instant and robust fire. This is now the third bad connection I've found between a wire end and connector over 2 years. In each case I had to strip away the insulation over the clip to see it.
I think a year ago, Geo said a new harness was a good investment. Maybe when I retire...
