trrdster2000
Well, who knew. The Spitfire hand brake has a couple of intermittent guides for the cable as does the GT6. We saw this and were not sure how it all was located on the two cars. The Bentley's for each car shows squat on the guides, nada. While the body was still on the Spit frame we went to the warehouse and turned the GT6 body on it's side and found the brackets welded to the body at the end of the tunnel, OK, proceed with the hard stuff. We were taking the body off and going to hang it up went things started going wrong. Checking for clearance as we started up, the hand brake cable and the brackets were hanging up. The brackets are welded too the frame on the Spit, now what! It looks like they had to do a little different arrangement and move the pivot point forward, because of the large donuts.
The short story, cut the brackets off the GT6, clean up and cut the welds off and prepare to weld on the Spit body tunnel. As info on the cable, they are different.
Now to the alternator, hope one of my extra TR6's ones will work. The one off the Spit was dropped and broke the ear off the rear bracket. The GT6 one is a different case, only by about a 1/4 inch, but will not work, internal parts in the casing will not let you line up the three bolts. Not all problems are created by the cars difference, dumb ass plays a big part in wasting hours.
Wayne
Wayne
Hi Guest!
