sorry guys - think i'm in way over my head ...
Trying to add a simple (ha!) volume control to a 6v audio circuit.
Output is from an 8pin DIP audio amplifier chip, 400mW.
Using the output directly to the speaker (a small 8 ohm), the volume is just a tad high. I added a 5k ohm potentiometer between the chip and the speaker positive, and there's no sound whatsoever for 90% of the turning range. Last bit of turn and the volume zaps up to max very quickly.
Also tried the same using a 10k ohm pot. No difference.
How do I figure the correct size of potentiometer?
The audio amp chip is an LM386N, RadioShack # 276-1731. Vs = 6v, Rl = 8 ohm, P out = 125mw, f = 1kHz, pins 1,8 open.
Edit: Both pots are audio-taper, 5k (or 10k) ohm, .25 watt.
I know that the source impedance should normally be no greater than 1/10th (0.1) of the pot's stated resistance. Further, the load resistance or impedance should be 10 times the pot's resistance to prevent the taper from being adversely affected. But I don't know how to measure the source impedance and load impedance. Dumb me.
Thanks anyone!
Tom
Thanks anyone!
Tom
