My '75 MGB had air horns (Fiamme) fitted which have stopped working. The wiring for the air horn relays is a bit puzzling - a fused hot wire (red) splits to power the relay which appears to be grounded back though the horn button wire (purple/black I think). The relay then is connected to the compressor and on to ground.
Anyway, I have bought the proper horms - one high, one low. I am now trying to figure out the wiring. If I wire up one horn with the fused live (red) feed to one terminal and connect the other terminal to the horn-push wire purple/black, it works fine. If I add the second horn in series they won't sound (just splutter a bit).
Here's the question - am I right in thinking that the horns are supposed to wired in parallel? That is, each will get a hot feed and both get connected to the horn-push wire (which I'll need to split).
Help please.
Help please.
