Just switched out my generator to an alternator using Dan Masters wiring info for the conversion and installed a Auto Meter Amp gauge. Worked great! Now I want to go to a Volt meter gauge. What is the proper connections for the Volt meter hook up? Currently the Lg.brown (10 amp) is connected to the "S" on the Amp and the Brown/White (10 amp) and small brown wire connected to the "I" terminal. Would this be the same for the volt meter?
Thanks for the help. /ubbthreads/images/graemlins/confused.gif
