Ineresting Bob said his rubs at the front, because mine rubbed at the rear upper a-arm and needed to be trimmed to avoid rubbing. The sharp corner of the arm just needs to be filed or cut off. All is takes is removing a triangle with about +-1/4" legs. The usual point of interference is at the outer edge of the inside of the wheel.
If you use original bolts, the length should be OK. If you use hardware store bolts, they might need to be trimmed or reversed so the head is rear to front to eliminate fouling. I also used 1/8" spacers up front.
YMMV but this is what I needed to do on mine.
BTW, on my TR4A, the steering stop is concentric so, not adjustable.
