I think the real question is why you wouldn't want to replace that plug anyway. They corrode from the inside out (dissimilar metals exposed to water) and when they blow, fill the crankcase with coolant.
That said, I've never had a head hot tanked, and never had a problem caused by that (as far as I know anyway). But be sure to remove the oil passage plug on the LR corner and make sure the passages are clean and clear.
