Hap Waldrop
BlueMax said:Are we talking about WHP? Or BHP here?
Alan, flywheel HP, meaning engine dyno, not chassis dyno. A few years ago, David Anton did a no holes barred 1380cc engine for the Classic Motorsport magazine project car " The Modern Midget " . Anyway it was very similar to your engine, almost to a tee, minus the billet crank and I beam rods which add no HP, it was almost the same, same cam, ported head, a little over 10 to 1 CR, almost identical to what you have built, he even had the DCOE on it, it netted 105 HP on David's Land and Sea engine dyno. I thinks that about the ceiling for a A series engine that is streetable on carbs.
We were able to get about 100 rwhp on Dick SCCA LP 1275 engine, which in almost all ways, via the SCCA LP engine rules was inferior to David's 1380cc engine, (SCCA LP rules allow no head porting, max valve lift of .450", stock rocker arms and stock HS2 carbs) except for CR, we are allowed to run 11.0 to 1 on the LP race engines, I think the higher CR was the only reason we were able to make more HP than a trick 1380, and if one could sneak the CR up a bit on the street, you could see a improvement on the strret engine, but fuel becomes a issue then, this may be a reason enough to try a aluminum head so you could run a higher CR, but thats can be dangerous and expensive game to play on the street, if you go too much on CR, then you doomed to octane boosters, race gas or getting another head.
These siamese engines love compression ratio, is by far the easiest way to mke HP, but we limited by the fuel we have for the street. The main reason we can get 140hp out of full tilt SCCA or vintage race engine is the CRs we were using, and the race gas we use, I've ran 1275 race engine as high as 15.5 to 1.
Alan, you could pump her up to about 12 to 1, and then run $10 dollar a gallon race fuel, it would be like you are paying Euro gas prices
