Skip & Lynne
I have a question for you electrical types. I just finished machining the mounts for the alternator on my BT 7 it is a 60 amp Nippondenso with 3 wires (ignition, sense and light). What do you do with the Lucas voltage regulator and whats the best way to wire it up. I will run the large hot wire to the starter solenoid and charge back to the battery with that. Thanks Skip
