Thought it wise to have the radiator checked before I stuck it back in so took it to a local radiator shop. Good news is , no leaks, bad news is the tech said it was probably between 50 and 80% stopped up. His knee jerk assessment was maybe rodents had nested in it since it has been sitting so long but we ruled that out cause all hoses were attached while it sat dormant.
When he shot a high pressure hose into it , it immediately overflowed from the filler neck but took a a few seconds for the water to exit the bottom. He said it should have come out much sooner within a second or two and the flow wasn't very strong when it did but wasn't convinced cooking would help much.
I don't know what the volume coming out the bottom should be or even how to test it. However, assuming it is indeed clogged, the fact that it doesn't leak at least gives me a reason to try and save it.
My question is, what could I pour into it that may help whatever may have it complugatized? I fear anything too strong would eat through the tubing and then it would be worse off than it is now.
