Hi Folks.. Here's what I did.. Using a very fine thread like string between two jack stands, I measured very closely the distance to the rear wheel. Making the string exactly parallel to the rear wheel. Then using the string at the front wheel and with the steering wheel straight ahead I set the front wheel to 1/16 - 1/8 toe in. Same thing on the other side. Seems perfect. When I take it for a test drive it was wrong. To go straight, I must keep the wheel turned significantly to the right and it's difficult to keep it going straight. I have done this twice. What am I doing wrong? Thanks in advance
