Hi Larry,
With modern tires, *a bit* of negative camber such as is on your car can be a good thing. It helps in cornering. Most road cars have a bit less than shown in your photo, but it doesn't look very radical either. It's a bit hard to measure accurately without the right equipment, you can only get a rough idea with a framing square such as you are using.
The alignment shop will use accurate measuring devices and install or remove shims at the lower/inner a-arm mounts to adjust camber. They usually measure in degrees. Somewhere between 0 and 1 degree of negative camber might be best on a street TR with modern tires (early TRs had up to 3 degrees *positive* camber, meaning the top of the tire tilted out, to work best with old-style bias ply tires). A racer might dial in 1.5 to 2 or even more degrees of negative camber, to make the car stick like glue in the corners. But, that can make for fast tire wear on the inside edge and isn't ideal for daily street use.
So have the alignment shop measure it, see what you've got and advise. I don't know the Goodparts items you mentioned, but doubt that any spacers would have much effect other than changing ride height.
The only problem is if there's insufficient adjustment available via shim removal. If that's the case, is it possible the upper fulcrums (on top of the spring/shock towers) are in backwards? I'm not 100% certain about TR6, but on some other TRs they can be oriented either way and it makes a difference. The same part is used but oriented opposite directions on TR3 than TR4, I forget which is which without looking it up. A manual will show proper orientation.
Another possibility, is the cross-brace in place, running across the engine compartment, bolted between the tops of the spring/shock towers? I've seen these removed and left off, and after a while the spring/shock towers can incline inwards more than they should. That would mess up front alignment badly, in the direction you are seeing there.
There are also several different cross braces used during TR production, but I don't know if they varied during the TR6 run.
Finally, was any work done on the lower suspension mounting brackets, that might have repositioned them farther outward?
If the cross brace and fulcrums are correctly installed, and there still isn't sufficient movement possible in the lower adjusting points to get it set up properly, the alignment shop can best advise you. They might want shim the upper towers apart by putting spacers under the cross brace, or heat and bend the vertical links, which are a couple possible solutions. Another is a set of adjustable upper fulcrums, such as Revington TR sells.
Hope this helps!
