/ubbthreads/images/graemlins/confused.gif I'm trying to get my AH BJ8 restarted after a long layoff in the garage and I am having trouble getting a spark. I've installed a new battery and checked all of my wiring up to the ignition switch and then onward to the coil. I've installed a new coil (Napa). The car turns over fine but I can't seem to get a spark from the coil. I can measure 12V from the negative post side of the coil and I've got good continuity from the positive post on the coil all the way back to the ground wire on the trunk battery switch. I'm trying to test the coil by removing the coil wire from the distributor cap and holding it near the engine block while the car is turned over. I'm looking for an intermittent blue spark. I can't seem to get it. Am I missing something simple or is this just an improper way to test the operation of a coil? Does anyone know a good book that details the proper efforts and checks for getting a car back on the road that has been put away (and in all likelihood was put away with any prep for storage) for about 7 years?
Hi Guest!
